mvnrepo new location for Tutorial build - temperature humidity
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 3.783 s
[INFO] Finished at: 2017-07-12T15:38:31-04:00
[INFO] Final Memory: 9M/123M
[ERROR] Failed to execute goal on project temperature-thing: Could not resolve dependencies for project com.ptcmanaged.thingworx:temperature-thing:jar:1.0-SNAPSHOT: Failed to collect dependencies at com.thingworxs:thingworx-common:jar:5.0.0: Failed to read artifact descriptor for com.thingworxs:thingworx-common:jar:5.0.0: Could not transfer artifact com.thingworxs:thingworx-common:pom:5.0.0 from/to ptc-managed-services-public (http://maker01.cloud.thingworx.com/mvnrepo): maker01.cloud.thingworx.com: Unknown host maker01.cloud.thingworx.com -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
Can you please provide latest mvnrepo directory?
Maruthi
Adrian Petrescu​ Could you help with this, or point to someone who could, please?
-- Craig A.
I am having he same issue. Would highly appreciate some help.
Thanks!
Also having this issue.
I can run maven on my Mac running OS X Sierra (latest revision) and the command mvn package command succeeds there but on the Raspberry Pi (running the latest Raspbian release Stretch) it fails with the error reported in the original post. The README.md file says that building on the Pi should work. I did install maven there as the README advises.
