Need Help with Toolkit
I was following Getting Started with Creo Parametric Toolkit but something failed and I don´t know how to solve it.
I tried to open make_install.sln through Visual Studio 2022 and build the solution, but an error occurred.
It says "Cannot open include file: 'stdio.h'".
I searched info about that bug and tried many things like uninstall VS, install other libraries. However, nothing works.
I also built "Hello World" in VS to check if "stdio.h" is avalaible, and nothing failed.
I will really appreciate if someone could help me.
Thanks!
AskarkeAnswer
It´s working now. I have included every single header and library manually,but now it works
Askarke10-MarbleAuthorAnswer
I had this issue, was able to resolve it by adding the stdio.h path to the project in the Include Directories... "C:\Program Files (x86)\Windows Kits\10\Include\10.0.22621.0\ucrt"
After is error was resolved I need to Library paths also...
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22621.0\um\arm64
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22621.0\ucrt\arm64
Just to follow up on this issue. I had the same problem with the stdio.h file not being found.
I used Theron's additions listed above adding the paths. Only difference for me is that my machine is x86 so latter 2 paths were just a bit different:
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22621.0\um\x64
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22621.0\ucrt\x64
Once I did that my build succeeded.
6-Contributor
April 4, 2023
What was the fix? I'm not seeing it. I'm getting the same error and I'm not sure what everything was you added.
Sorry mate, It's been too long and I don't even remember the problem I had.
With my license, Creo Toolkit is not available so I removed it from my Creo Parametric Customisation and I can't even check it to help you more.
I wish I could help you better than I did.
6-Contributor
April 5, 2023
No problem, thanks for replying. 🙂
