Apr 17, 2013 6:29 PM UTC
network security issues CREO 2
can anyone help?
  • We are able to install Creo 2 on our school network, thats no problem.
  • When students log onto their own profiles, (which only allows them to see a limited amount of drives on our servers) and go to open a file (File - Open) they are then able to see the entire school network and servers, giving them access to everything, creating a major secutiy issue.
My tech guys and managers have either given up or cant work it out. I have 3 staff trained, and over 100 students across 3 key stages ready to use it.
Has anyone come across this problem before? Im not a IT technician so I cant give you much information, but is there anything I can try or tell someone to try?
Any information will be greatly received.
Stuart
    Apr 18, 2013 6:36 AM UTC
    Hi Stuart,
    We have seen this problem in a small number of schools and understand it is related to how permissions are controlled within the network software. Network managers in schools who do not have this problem have reported:
    "Access to see and edit files and folders should be controlled with user and group policies." They went on to say: Relying on hiding icons and drives is not recommended in a school situation."
    Are your IT support staff able to edit the user/group policies in the way described?
    Tim
    Apr 18, 2013 2:14 PM UTC
    Hi Tim
    Similar security problems are also stopping us using CREO 2 with students. I have no knowledge of networks but our ICT technician tells me that the following is the problem:
    "For Creo to open when logged on as a student we had to enable the 'command prompt to process scripts' policy. This means that students can run batch files and scripts on the computer which is a security issue"
    We are using a RM CC4 network.
    Any further help you could provide would be most welcome. There must be an RM network manager out there somewhere that has the solution to this?
    Roy
    Apr 18, 2013 2:40 PM UTC
    Roy,
    You correctly point out that scripts must be enabled for ProE or Creo to run. However, it is not necessary to enable the command prompt.
    Under the command prompt option there is a sub-option to enable scripts. It is only the sub-option that should be enabled leaving the command prompt disabled for all students. Here are instructions kindly provided by Leon Wells, a network manager in a Staffordshire school.
    The student profile on some networks including RM has scripts disabled by default.
    Here is how this can be cured on RM CC3 networks.
    1. Start Management Console > Configuration settings > User types
    2. Double click on the student user profile then look under 'User type & software restrictions'
    3. Leave 'Disable command prompt' set to disabled
    4. Change the sub-option 'Disable command prompt script processing' to 'No'.
    Note: Pro|ENGINEER will run OK with access to command prompt left disabled.
    There may be slight differences in CC4 but RM should be aware of this and be able to support your IT support staff.
    Let us know how you get on.
    Tim
    Apr 23, 2013 9:24 PM UTC
    Typically in networks managed by windows servers (and others?) group policy manages the security of folders. Even though students can see the whole network, they should not be able to open, edit, launch or delete files that they shouldn't . Group policy will have them locked in to their own folder using %username% variable. If the network is visible by browsing using the Creo file Open dialogue, students would be able to get there using any number of tools. Just having things apparently hidden is not security, group policy is.
