No graphic interface
I downloaded and installed a student version of Creo (parametric).
Everything is fine, except the graphic interface, that is missing.
I can draw, i can extrude ... , i see it in the tree, but i don't see what i'm doing (2D or 3D result).
I even exported it in PDF, then i saw what i did. So everything is right, but i can't see what i'm doing... and it's a little bit annoying.
Does anybody got an answer, or an idea to help me?
Thank you!!!
Franck
    MarkCheliAnswer
    Hi Franck,
    It does sound like a graphics driver issue as Doug said. My first recommendation would be to update your graphics drivers. As this is different for each type of graphics card, I cannot send you a step-by-step guide. A google search should show you how if you do not already know.
    Let me know if you are still having an issue as there are other solutions that we can try.
    Hey Franck - welcome to PTC Community! I've moved this discussion into our forums so that the team there can help you troubleshoot this issue.
    Cheers,
    - Ryan
    Sounds like a graphics driver issue. What graphics card & driver are you using?
    MarkCheli5-Regular MemberAnswer
    Hi Franck,
