9-Granite
May 31, 2012 9:11 AM UTC
Opening ProD files in Creo
Hi all i think i already know the answer to the question.
Is there anyway of opening a Pro/Desktop des. file in Creo.
I know we used to be able to open them in earlier versions on Pro/E which I have done before and these files open on Creo.
Problem is the only version have of Pro/E is wildfire 5 and i don't have a licence file.
Not a problem normally but when I install and contact the PTC server to download the licence file it tells me that I have surpassed the amount of times I can download a licence file.
Any ideas for a quick solution.
Just want to open the models and re render them.
Simon
    May 31, 2012 1:45 PM UTC
    Simon,
    The license generating server was broken last week. If you want to, you should be able to generate a new license now.
    After you open those files it might be a good idea to save them in Creo-Pro/E format.
    Adam
    18-Opal
    May 31, 2012 1:48 PM UTC
    Simon,
    For Pro/D files...you need to use Creo Elements/Pro or earlier to open the native file and save it as a Creo format file. Then you can open it in Creo.
    Mark
