Parametric will not start
I installed Creo Parametric 8.0.3.0 with a student license without any problem for the most part. It told me I need to get JRE 11, so I got that through AWS. Now, all Creo services open up fine except Creo Parametric. I double click it and nothing happens. I would appreciate some help here
Update: I uninstalled and reinstalled Parametric and it fixed it. Thanks for the help anyway.
1.] JRE is not mandatory, Creo does not need it to run
2.] please publish detailed configuration of your computer
3.] look into Event Viewer for some error message relatedx to parametric.exe or xtop.exe
Im running Windows 10 on 21H2. I have a AMD Ryzen 3700X and Nvidia RTX 2080S, all up to date on drivers
I found nothing in the Event Viewer
YR_103125331-VisitorAuthorAnswer
