pro_material_dir and Windchill
Hallo,
Thanks to the new Windchill 10.2 Server I was able to check in a *.mtl file.
But her is my next Problem. How must I type the path at the pro_material_dir parameter in the config.pro to link my material library to the windchill folder?
I try this: pro_material_dir "https://academic.ptc.com/Windchill/Projekt/Formula_2015 - LA ERacing/Ordner/creo_bib/material"
but it didn't work.
    sm_01Answer
    Robert, this is not the right syntax for a Windchill folder path in Creo's config.pro file. The proper way to set the path is to browse for it from the Creo Options Configuration Editor. Use File, Options, Add, enter pro_material_dir and then pick the Browse button. Choose your project and folder and the end result will be something like this:
    • wtpub://FIRST/Projects/<YOUR_PROJECT_NAME>/Materials
    sm_011-VisitorAnswer
    robwood1-VisitorAuthor
    Thanks a lot for the help.
    Now it all works fine.
