Oct 31, 2011 4:21 AM UTC
Problem Editing Features in assemblies in Creo Schools Edition
Hey: I cannot edit features of a part when I am in an assembly. I just switched over from Wildfire 5.0 to Creo. and did not have this problem in wildfire schools edition. Any ideas?
    mfischerAnswer
    18-Opal
    Oct 31, 2011 2:32 PM UTC
    Hi Rick,
    What edition are you running?
    To show the "+" symbol....do the following.
    1) Open the assembly
    2) Click the small Tools Icon (hammer/wrench) to the right of the text 'Model Tree' in the model tree.
    3) Select Tree Filters
    4) Check Features in the Model Tree Items dialog.
    5) Click OK.
    Now you can see the "+" symbol.
    Mark
    18-Opal
    Oct 31, 2011 12:03 PM UTC
    Hi Rick,
    Like with prior releases of Pro/ENGINEER, when in Assembly Mode, you need to activate the part you want to edit in order to make feature modifications. To do this, just right mouse button on the part in the graphics window or the model tree and select Activate. This will activate the part so you can modify features, make new features, etc.
    Alternatively, you can open the individual part and male the same changes.
    To activate the assembly level again, just right click on the top level assembly model in the model tree and select activate.
    Hope this helps.
    Mark
    Oct 31, 2011 2:13 PM UTC
    Hi mark: Thanks for the reply.
    I am able to activate the part, but there is no "+" before the part that I can click on to access the features in the part. that is why I cannot edit the features.
    I just reinstalled Cleo and deleted my student copy of WF 5.0. I don't know if that has anything to with it.
    I hope this helps with PTCs continual improvement.
    mfischer18-OpalAnswer
    18-Opal
    Hi Rick,
    5) Click OK.
    Mark
