Dec 11, 2025 9:40 AM UTC
problem "error" with the licence
Hello, i want to install creo 9 University edition for my studies.
When I entered BK120908EDUNIVERSITYED under sales number order or product code. It didn't go through and displays ERROR in red.
Same with the BK900908EDSTUDENTEDUNI code which some people of my university used.
I alredy had creo and my licence expired so i needed to install it again and i have already done it with the second sales number. But this time, it says "error" to me.
Dec 11, 2025 12:26 PM UTC
put following words into Google search and study results.
windows how to get physical address of network card
Dec 11, 2025 10:00 AM UTC
hello, i also saw that i could do that
 You can contact academicsupport@ptc.com (via e-mail). You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
  • if Ethernet network card is installed in your computer then use its physical address
  • if the only network card is WiFi network card then you must turn off MAC address randomization to get real physical address"
But i do not know if it is the same for creo 9 because it was the answer for creo 12,
And i do not understand where is my host ID, is it the login name for creo ?
Thank you for you answers
