MarkCheliAnswer
Tammay,
From the looks of it, you have an incomplete download. The total size size should be much larger. All you need to do is try the download again. If you continue to run into this problem, I would recommend trying to move to a more stable connection.
I hope that helps!
MarkCheli5-Regular MemberAnswer
Tammay,
I hope that helps!
