Aug 13, 2010 5:41 AM UTC
Problem Installing Pro/E Schools Edition WF 5.0
I'm trying to get the schools edition to install as I'm an engineering Ph.D student. I've been trying for several hours to complete the installation but nothing seems to work. It hangs at 1% or 2%.
I've now apparently hit the limit of my license requests to try and install so I'm out of options.
I'm running Windows 7 Pro x64. It's all updated, in fact the last group of updates was done last night.
I've tried turning off all other programs in the background. Tried restarting. Tried deleting all the temporary files it installed (when I select Cancel Installation it just freezes) and rerunning the installer. Tried redownloading the installer four times now. Tried installing by extracting to a temporary folder as well as to the Program Files (x86)/PTC.Setup folder. Nothing i've tried was successful.
I haven't been able to find an installation log file to see what it's hanging on.
Has anyone else run into this or have any ideas on what else I might try?
    Aug 14, 2010 6:59 PM UTC
    Thank you
    Aug 14, 2010 10:55 PM UTC
    I also have this problem...and would like to find out how to fix it. Thank you for asking the question. 🙂
    Aug 15, 2010 12:44 AM UTC
    also having the same problem on a macbook pro i7 with windows 7 ultimate and a built desktop with a 920 i7 running windows 7 professional
    both computers are running 64 bit versions of the OS with all current updates
    Aug 15, 2010 9:17 AM UTC
    Glad i am not the only one !! fortunately i have been able to download succsesfully and save to my documents, unfortunately when i try to install things go pear shaped ond there is no content.
    I have tried several attempts to over come this but to no avail.
    I hope this can be sorted by the PTC crew.
    Aug 15, 2010 11:39 AM UTC
    I tried again !! took 1 hour 40mins to down load, got as far as you did and stopped at 2%.
    Must be doing something wrong but i am confused as to what !!
    Please help PTC guys !!
    Aug 15, 2010 3:35 PM UTC
    i tried downloading and installing on a windows virtual machine running xp 32 bit and had no problems, so this is clearly a conflict with the windows 7 installer. I also tried using the 32 bit installer on my windows 7 machines and it would error in the exact same place.
    18-Opal
    Aug 16, 2010 12:26 PM UTC
    Hi all,
    Thank you for raising this issue with PTC. I am making steps to address the 'install from the web' process.
    Since, Pro/ENGINEER Wildfire 5.0 is now offered on DVD, we wanted to provide an install process that would not require users to download the full media DVD (3.6 GB). The intent was to allow users to download a small executable which would initiate PTC.Setup. During the install, the required files would be downloaded from ptc.com.
    Depending on network connectivity, we are finding a number of users not able to successfully complete the install via the 'install from the web' process. For this reason, we will provide a link to download the full media to users local machine.
    I am anticipating this to be available by the end of the week (August 20, 2010). When available, I will post a reply stating it live. On the page, where you downloaded the setup executable, you will see a new link for downloading the full image. Once downloaded, you can unzip the file and perform setup from the folder. This will allow you to successfully install the edition.
    If you have future issue, please send an email to -.
    Mark Fischer
    Director, PTC Education
    rbram1-VisitorAuthor
    Aug 16, 2010 11:02 PM UTC
    Hi Mark,
    Thanks a lot for the reply! I look forward to using Pro/E when you get the download ready.
    Aug 11, 2011 11:41 AM UTC
    Has there been a fix for this problem? I too had the same installation issues as some of the original posters so I clicked on one of the alternative downloads to install the DVD version and it uploaded about 2/3 of the zip file and when I tried opening it, it said it was invalid.
    This is insane. I expected a way better experience from PTC then what I'm getting.
    Aug 11, 2011 12:57 PM UTC
    hi James, can you please email me (-) your best mailing address and i will ship you a physical DVD?
    thanks
    dima
    Sep 5, 2011 6:01 PM UTC
    I've downloaded Pro/E 5.0, but when I try to install, the setup just do not run.
    I'm using windows 7, I've tried both double clicking and running as admin the setup.exe, but nothing happens, does anyone know how to solve this problem? (The same thing is happening when I try the Pro/E 4.0)
    I'd like to ask one more thing, does the Pro/E school ed. includes the Mechanica so I can simulate servo motors?
    Matheus
    PS: Sorry for my poor english, long time without use.
    Sep 6, 2011 6:52 PM UTC
    Hi Matheus,
    does the software give you any error messages?
    thanks
    Dima
    Sep 6, 2011 9:25 PM UTC
    Hi Dima,
    No, it just do not run, no errors, no messages.
    I realy don't know what to do, I've already tried changing windows compatibility mode, but no changes.
    Matheus
    Dec 3, 2011 10:56 PM UTC
    I have this same problem... nothing happens when i run the setup!
