Problem of sweeping
Hello Everyone,
I have a problem of sweeping. When I choose the option 'solid', the option material removal is activated by default and I had no way to change that. I use Creo parametric 6.0 for students.
Could you help me please?
Dale_Rosema
Are you in a part or an assembly? If you are in an assembly, you cannot add material in Creo.
@JK_95.25 wrote:
Hello Everyone,
please explain what are you doing.
Do simple test ... create new part and start Sweep feature creation.
JK_95.254-ParticipantAuthor
it worked in the part. Thanks
Dale_Rosema
i'm in an assembly. Ok i see.
