Problem while creating a service to consume an xml web page
Hi, I am following the course and I'm right now at the capter 3 "Connecting to External Data Sources with ThingWorx 6.5"; when I have to create a Service to consume an xml web page I have some issue:
I'm following the guide
  • Type ACMEV in the spotlight search field.
  • Select AcmeVendingCorp.
  • Click the Services link.
  • Click the Add My Service button.
  • Type GetThingWorxFeed in the Name field.
  • Type This service will retrieve the ThingWorx RSS Feed in the Description field.
  • Select the Inputs/Outputs tab.
  • Type Resulting Table in the Description field.
  • Click the Base Type drop-down list to expand it.
  • Select INFOTABLE.
  • Select the Snippets tab.
  • Click under the left-most scroll bar to scroll down to ContentLoaderFunctions.
  • Select ContentLoaderFunctions.
  • Click the Add button for the GetXML snippet.
  • Edit the URL parameter line to url: "http://www.ptc.com/feed/press",
  • Click the Done button.
  • Click the Save button.
Then I'm supposed to go on http://www.ptc.com/feed/press with my browser but it redirects me on the page www.ptc.com/news; I can't see any xml.
Plus, if I go further to the end, according to the video, I should see this message
Unable To Convert From com.sun.org.apache.xerces.internal.dom.DocumentImpl to INFOTABLE
​but what I see is:
Wrapped org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 10; DOCTYPE non è consentito se la funzione "http://apache.org/xml/features/disallow-doctype-decl" è impostata su true. Cause: DOCTYPE non è consentito se la funzione "http://apache.org/xml/features/disallow-doctype-decl" è impostata su true.
May you help me to understand where the problem is?
Fabio, the URL posted there does not work anymore. You would have to use different RSS feeds. Here's a thread posted by Scott and here's one more posted by Adam that has alternative links.
fmanniti1-VisitorAuthor
Thank you
I Know this is very late, but I found a feed that you can use:
https://www.nasa.gov/rss/dyn/breaking_news.rss
In case someone is having the same problem, it helped me complete the training course.
