Nov 5, 2010 1:32 AM UTC
ProE 5 will not start
I installed ProE 5 Student Edition from my school back in August. From what I remember, it worked fine then. I recently tried to use it for a class but it would not open at all. There was no error message or splash screen. When I open it on my desktop, it will show the mouse as "busy" and then open, but on my laptop, I click the icon (or the start menu, or even the exe in the program files) and it flickers to busy but immediately stops.
I've tried uninstalling and reinstalling many times. I've copied over the files from my desktop with no results. I've cleaned out the temp folders and fixed my registry with CCleaner (nothing ptc or proe related though). I've tried updating my video drivers and even adding that line to disable them in config.pro. Nothing has worked. It doesn't even start up in safe mode either.
What is wrong and how can I fix it. All and any help is greatly appreciated!
Ross
    Nov 5, 2010 3:30 AM UTC
    This is a tough one. No simple answer and not enough info. You should at least state the Graphics card and OS version.
    I'm going to try to help, but I'm from the Unix world.
    Basically Pro-E starts from a script, not a binary. It needs to set some environment variables before it can start. That said, first try to start it up from the command line. Different versions of windows has it in some different locations. Sometimes it's called the "Command Prompt". Go to Start > All Programs > Accessories > Command Prompt. Basically you want to enter the line from your shortcut into there. Move the mouse cursor to the shortcut and "right-click" on the icon and select "Properties" This should show the location of the start script. Enter this into the Command Prompt. It should reveal at least some error message and possibly give a clue to what's wrong.
    Nov 5, 2010 3:50 AM UTC
    Thank you for replying quickly!
    Both computers are running Windows 7 Pro with my desktop using an nVidia GeForce 7950GX2 and my laptop running an ATI Mobility Radeon HD 5870. My desktop is using an Intel Core 2 Quad Q9450 and the laptop an Intel Core i7 Q720.
    I ran the cmd command on both computers and while it worked on my desktop, it again did not work on my laptop, but it didn't give any errors either. I am perplexed myself as to what it may be. Any other suggestions?
    Ross
    Nov 5, 2010 4:00 AM UTC
    So basically you entered the command and it just returned back to the prompt and nothing displayed or it never returned back to the prompt?
    My next question is what was the command you entered?
    Nov 16, 2010 4:34 PM UTC
    I recently reformatted and reinstalled everything on the laptop. Even with a clean OS install and new install of Pro/E, I still cannot get the program to start. It has the exact same issues as last time. There is no process in the task manager either. Could I need to install DirectX or would that have been installed with the graphics driver?
    Also, how does one go about editing the config.pro file as I may have done that incorrectly, and thus never tried running it without gfx hardware?
    Has anyone been able to run this program with this graphics card?
    Nov 16, 2010 8:44 PM UTC
    You need to edit the file config.pro or create it. The default location is at:
    C:\Program Files\proeWildfire 5.0\text\config.pro
    Enter the line:
    graphics win32_gdi
    This should turn off the requirement for accelerated 3D OpenGL graphics.
    Also in the "Installation and Administration Guide" for wf5 states
    You can run Pro/ENGINEER in the Direct3D 10 graphics mode on the Windows Vista operating system. Set the value of the graphics configuration option to d3d to run Pro/ENGINEER in this mode. Direct3D 10 is an API provided by Microsof that enables you to render 3-dimensional graphics accurately.
    basically:
    graphics d3d
    Try the config.pro entry things let us know the results. Do not add both "graphics" lines, only one at a time to see if it works.
    By there not showing any pro-e process in the task manager just confirms that pro-e is not hanging. There is something causing it to shut down before graphics startup
    Nov 18, 2010 2:23 PM UTC
    Does the graphic configuration fixed the problem?
    Can you check the size of the installation folder?
    Can you check for any sdt.err or sdt.out files in the start-in folder (by default is My documents)?
    The fallowing executables should be allowed to run on your machine (firewall and/or antivirus):
    - for 32 bit machine:
    <installation folder>i486_nt\obj\xtop.exe
    <installation folder>i486_nt\obj\pro_comm_msg.exe
    <installation folder>i486_nt\nms\nmsd.exe
    -for 64bit machine:
    <installation folder>\x86e_win64\obj\xtop.exe
    <installation folder>\x86e_win64\obj\pro_comm_msg.exe
    <installation folder>\x86e_win64\nms\nmsd.exe
    Nov 19, 2010 3:30 AM UTC
    None of the config.pro changes helped. I added a firewall exception with no success. The folder size is 2.92 GB or 2.96 GB (size on disk). I found a std.out file along with a ptcsetup text file. The ptcsetup file states that activation failed at the very end. The std.out file is attached. It seems to be a license issue, but I'm using the same license from my desktop and it works fine on that system.
    Nov 22, 2010 2:41 PM UTC
    Creo Elements/Pro Schools Edition license is locked to the Host ID (physical address) of your computer; you cannot use licenses created for other PC...
    Please send an email to - to request a new license for that machine.
    To find out your Host ID, click Start and choose Run. In the Run dialog box, type cmd and press RETURN. In the DOS window, type ipconfig/all. Look for the network Physical Address for your Host ID. The Host ID also appears in the bottom-left corner of the first screen in the Creo Elements/Pro installation.
    Jul 7, 2011 1:30 PM UTC
    I saw the same thing happens on a machine in our lab. The problem was a environment variable set with the wrong type. The variable was the path of cmd.exe
    Aug 3, 2011 10:52 AM UTC
    Using WF4.. on Windows 7, having an issue that sounds similar to this..
    PROBLEM?
    Program has worked fine for a while.
    Now, program does not start at all.
    Only nmsd.exe process is running in the 'Task Manager'
    and the std.out file gives only: "Serious internal error; cannot continue."
    CAUSE?
    In saving some config options i saved over the top of the config.pro file (not just the current session file).
    I suspect this has thrown something out that the program needs to start up? (paths?,variables?)
    RESOLUTION?
    Have tried uninstalling / reinstalling - no different
    Now looking for a config.pro file? (Unfortunately I didnt have the original backed up before i saved over it..)
    Any ideas help much appreciated..
    Aug 3, 2011 1:24 PM UTC
    Pro/E will read config.pro files in the following order:
    1. Global: C:\Program Files\ProENGINEER Student Edition\text
    2. Home Directory: This is typically Documents or My Documents
    3. Start In folder: The folder that Pro/E starts in.
    If there are any config.pro files in these locations, temporarily rename the files to config.bkup and then try starting Pro/E without them. This will verify if they are the cause of your problem.
    If you can verify it is the config.pro file, you will need to comment out lines of the config.pro file (using an "!" mark) to find out which option in your file is causing the problem.
    Adam
    Aug 9, 2011 8:36 AM UTC
    Are you connecting through the same network adapter you used when it was installed? I had the same problem as you, suddenly Proe 5 would not start, no splash screen or anything. I had moved my PC and connected to the internet via a lan cable instead of wireless. Refitting my wireless card solved the problem. Its based on the mac address of your licence, found in Program Files\ProENGINEER Student Edition\text\licences\licence.dat Look for the line PTC HOSTID=HOSTID= and then what follows is the (not to be confused with apple mac) MAC address that Pro engineer is expecting. To compare it with your current MAC address open command prompt, and type ipconfig /all and look for "physical address" of your network adapter. This must be the same as the number in your licence.dat file for Pro engineer to start.
    Jan 25, 2012 8:44 AM UTC
    I have tried EVERYTHING mentioned in this thread, and I'm still having the same problem. No splash screen, no nothing. Like a previous poster mentioned, I used it successfully for a few months, but now it's completely unresponsive. Seriously cramping my homework style...
    Feb 1, 2012 3:32 PM UTC
    Rachael,
    Sorry your having the problem. Could you please send a support request to -? Someone from the Academic Program support team will get with you to fix the problem.
    Adam
    Apr 11, 2012 1:03 AM UTC
    I have the same problem. I tried everything in this thread... it is a q9400 4x2,67ghz, gtx260, windows 7 64bit ultimate sp1. I can not do my cad programming on my 11,6" notebook....
    Nov 19, 2012 8:49 PM UTC
    I have similar problem with Windows 7 x64 and ATi Sapphire X1950XT 512MB DDR3 (opengl 2.0). After some fiddling with drivers and config.pro options I managed to solve the problem.
    1. Install Catalyst 7.11 (my choice) or 8.12;
    2. Set config.pro options:
    enable_opengl_shader yes (Catalyst 7.11) or no (Catalyst 8.12)
    graphics opengl
    use_software_opengl no
