PTC Creo 9.0 setup.exe file doesn't run
  • October 3, 2023
  • 4 replies
  • 2094 views
I'm trying to install PTC Creo 9.0 on my Windows 10 Pro 22H2, but the setup.exe file doesn't work. It doesn't even run when I run it as administrator, even if I disable the firewall application.
Best answer by MartinHanak
  • create C:\install directory
  • move unzipped installation package into C:\install directory
  • run setup.exe from C:\install directory
Which folder are you running the installer from?
Hi, I'm running it from Downloads folder. Does it have to be run from any specific folder?
