PTC Creo Installation issue
Hi!
I have downloaded the PTC creo for the student but at that time I forgot to save the pdf file of the quick installation guide. I guess in that pdf file there is a license key. Now I am not able to install the PTC creo as it will require a license key. I needed to install the PTC creo urgently. Can you please help?
Nusrat
rghadgeAnswer
@ny_01_9811507,
Did you get the chance to look back at this post and update the status?
@ny_01_9811507,
Which version of Creo Parametric you wish to use?
You can refer http://apps.ptc.com/schools/references/install_creo7_unistudent_standard.pdf for Creo 7.0 Installation Guide PDF.
@NY_01 wrote:
Hi!
Nusrat
K-12 students can use Product code BE700908EDSTUDENTEDK12
University students can use Product code BK700908EDSTUDENTEDUNI
The above codes are valid for Creo 7.0.
rghadge17-PeridotAnswer
@ny_01_9811507,
