May 3, 2013 5:28 PM UTC
PTC Creo - Parametric gears for laser cutting
These gears have involute teeth so will mesh correctly and transmit motion smoothly.
The zip file contains a PDF that explains how everything works including exporting a DXF to cut the gears on a laser cutter.
    May 3, 2013 6:04 PM UTC
    Great document, Tim!  Generating that involute always gets me.
    Do you have the non-educational version of Creo available?  I cannot open the models with the full version of Creo.
    May 3, 2013 6:09 PM UTC
    That's beautiful Tim!  One of my FIRST, FRC coaches is also a physics teacher.  I was mentioning the importance of involute tooth geometry and hadn't gotten back to him on decent documentation!  Thank you for taking care of that for me!
    I especially like the involute equation in developing the tooth geometry for these gears!
    Thanks!!!
    May 3, 2013 6:10 PM UTC
    Dude, we really need to get you involved in mentoring a FIRST team!!
    May 5, 2013 2:50 PM UTC
    Tim - This is excellent and really demonstrates the power of a parametric drawing program. Is it just me or is the mesh between the gears incorrect? Unfortunately, I don't yet know enough about the Mechanism Application to put this right for myself.
    I look forward to 'playing' with this more.
    Roy
    May 6, 2013 12:01 AM UTC
    Roy,
    Thanks for the kind words. When setting up a a gear connection its possible to align the teeth but when one of the gears is resized the mesh changes. It's possible to realign the teeth after re-sizing.
    The Precision LMS modules on mechanisms should fill in all the gaps.
    Tim
    May 9, 2013 10:12 AM UTC
    I cannot claim the credit for the individual models.
    I believe the original came from a German AE, It worked really well but was not very student friendly with no annotation and letters representing variables.
    Adam Haas did a major re-design on the parametric gear model with variable names and annotations.
    I created the gear assembly so students can define the ratio and run the analysis to check everything works before outputting to manufacture.
    May 9, 2013 10:17 AM UTC
    We are in disussions with the Institute of Engineering and Technology (IET) about launching FTC in the UK but funding is a stumbling block for them and prospective teams.  Last time I checked, the FTC kit costs nearly £1000 ($1500) here in the UK and that doesn't include the entry fees!
