raspberrypi - thingworx - android phone - how to connect LSR and phone to same thing?
Hi All,
I need to fetch some data from raspberrypi onto thingworx thing and it needs to be accessible via an android phone.
I installed EMS on RaspberryPi and that is bound to Thing - PiThing.
I am able to read Temperature data and trigger GPIO pins (led lights) directly from Thingworx.
But when i created an Android Application to pull this temperature data and to turn led lights on/off, the thingworx thing got bound to android app.
Is there anyway to do this?
Should i approach it another way?
Any help is appreciated.
Thanks and regards
Maruthi Ayyappan
Maruthi,
Would need to understand how you are using the android - are you using the same name PiThing and can you explain more your intended use model
