Oct 2, 2021 2:01 PM UTC
Re: Creo student version not runnig after installation
As per this thread - Same problem
i5 4th generation
8gb ram
Windows 10pro 64
1tb hard disk
Intel, Amd Radeon graphics
👉Creo version is 7.0.2.0 Student version
After complete  installation  finish. When I click on creo parametric  nothing is happen! 😔
Please help me.
NOTE 👉When installation was  completed  creo  parametric shows 👉installed with warnings ⚠️
Oct 14, 2021 10:07 AM UTC
My problem is solved. and I want to give you a bonus tip.
after many many tries........... When I opened my Settings, I noticed that there were a lot of updates pending on my laptop. Then I downloaded and installed all the pending updates, a miracle happened after all the updates, my creo software started running very smoothly, and I was very happy to see it.
You can give this tip to anyone because this tip is very useful and very accurate.😊
Oct 5, 2021 5:16 AM UTC
i5 4th generation
8gb ram
Windows 10pro 64
1tb hard disk
Please help me.
modify Creo startup shortcut to contain -g:win32_gdi parameter
Example:
"E:\PTC\Creo7_020\Creo 7.0.2.0\Parametric\bin\parametric.exe" -g:win32_gdi
Oct 6, 2021 7:27 AM UTC
Now I have installed  Creo 8.0 in same system  it is successfully installed .
But  it running very slowly. When I click on anywhere it freezing/hang (pop-up shows creo student versionis  not responding) at every 5-6 seconds.
(Not responding)
(Not responding)
(Not responding)
.................................. (Not responding )!
Oct 6, 2021 7:33 AM UTC
(Not responding)
(Not responding)
(Not responding)
open config.pro file in Notepad and add following lines at the end of the file.
enable_3dmodelspace_browser_tab no
enable_partcommunity_tab no
enable_resource_browser_tab no
web_browser_homepage about:blank
NOTE: config.pro file in my installation is located in E:\PTC\Creo8_000\Creo 8.0.0.0\Common Files\text
