May 6, 2016 5:21 PM UTC
Relicensing Guides
    Aug 31, 2016 12:15 AM UTC
    We have several installs of Creo Parametric 3.0 M040 that we installed exactly one year ago for use with a First Robotics team.  All of the licenses have expired at this point.
    Both of the relicensing gudes above (standard and premium) indicate that there should be a "reconfigure.exe" under the C:\Program Files\PTC\Creo 3.0\M040\Parametric\bin folder.
    Reconfigure.exe is not there.
    How do we reconfigure for another year?
    Sep 12, 2016 3:04 PM UTC
    Didn't see any Reconfigure.exe in the file too
    Oct 25, 2016 3:46 AM UTC
    I got the process to work,  but I also had to delete the old expired license files to make it run (and remove the reference to them in the lower pane of the reconfigure program, by clicking on the minus sign.)
    Nov 13, 2016 8:30 PM UTC
    After downloading creo and following the steps provided, every time i enter in the product code BE400407EDSTUDENTEDK12 into the simple license entry i get the login details option which i enter. After this point it looks as if the programme will continue until in stops responding and shows error?
    Nov 14, 2016 4:47 PM UTC
    Hi Ciaran,
    We have an issue with the licensing in our system and we are working to fix it as soon as we can.
    In mean time, you can run setup.exe>Install New Software>Next>Accept Agreement>Next>in the Simple License Entry product code, enter the Product code (BE400407EDSTUDENTEDK12)>click install licensing (you might get a red error (Invalid Requestid))> check your email and you should receive a license> save the license on your computer>then drag it to the License Summary box. if you see any license in the License Summary box, click minus to remove them. Wait for license to be available>next>install>after the installation is complete>click finish.
    Let me know how it goes.
    Nov 15, 2016 12:27 AM UTC
    Hi
    I've been trying to follow the steps suggested in the different emails and hoped Abdul's idea would work.  Unfortunately, we aren't able to get CREO to run.  It looks like everything has worked, but we can't open the software.
    The message is:
    License request failed for feature
    ​Any suggestions?
    Nov 21, 2016 4:56 PM UTC
    Hi Abdul,
    Using PTC/Creo 2.0 academic version here at Holy Name High School .
    Have  been using this software for about 4 years now in the classroom.
    Today all the clients and the server are failing on the license screen.
    Clients say the 7788@cproom01 (-96) License server machine is down or not responding.
    The server says the License is invalid.
    I have tried several times reinstalling a backup license with no luck.
    We have about 25 clients and 1 Server  all down.
    This happened about 2 years ago and we got an updated license and all was well again.
    Please help if you can.   My class is completely down today.
    -Brett Penza
    Worcester, MA
    Nov 21, 2016 6:33 PM UTC
    if server says the License is invalid then I expect it is network card problem. Look into license file ... on SERVER line you will find PTC_HOSTID, this means MAC address of network card.
    Open Command Prompt window and run ipconfig  /all command. Look for PTC_HOSTID in command output. If it is not present then (probably) the valid network card has been disabled.
    Note: Academic licenses are not permanent, expiration date is written on INCREMENT line.
    MH
    Feb 16, 2017 8:07 PM UTC
    I'm using windows 10 and the reconfigure.exe doesn't run.
    I've tried selecting run as admin and is still doesn't work. My cursor changes to loading for a second or so then nothing opens.
    Any ideas? Or can I update my license manually?
    Feb 17, 2017 5:40 AM UTC
    if I were you I would try new installation of Creo into new (this means different) installation directory.
    MH
    May 23, 2017 8:50 AM UTC
    Thank you,
    This saved me when working on a procrastinated assignment.  Had a mild panic attack when creo would not open due to licensing.
    Jun 19, 2017 7:00 PM UTC
    Dear Abdul Abdulkarim,
    students can download Creo 4.0 from https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page. Unfortunately nobody knows Product code for Creo 4.0. Please can you resolve this problem ?
    MH
    Jun 19, 2017 7:09 PM UTC
    Hi Martin,
    I don't think, the free edition of Creo 4.0 University Student is available for university students.
    Abdul
    Jun 19, 2017 7:15 PM UTC
    please can you explain why Creo 4.0 download link is available on https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page ?
    MH
    Mar 12, 2018 8:27 PM UTC
    I follow the steps but cannot enter the new product code because it is grayed out, is there a reason it is grayed out?
    Mar 12, 2018 8:33 PM UTC
    please provide details about every step you did.
