Apr 28, 2010 11:48 AM UTC
Rendering with Wildfire 4.0 MO92 Schools Edition.
Hello all, I'm having problems increasing the final resolution of photolux rendered assemblies. Currently, a 150mm x 150mm (70x70x70 assembley size) image at the highest settings, including the rendering of 'transparent' materials takes about 4-5 hours, yet only produces a 72dpi image. I'm using Wildfire 4.0 MO92, Schools Edition. Ultimately I'd like to produce images that are at least 300dpi, so: A: can I increase the output resolution size (in dpi)? B: is it possible to export .spl file extensions, so as to import into 'Blend'? C: Is anyone currently running ProE across a Linux based Beowulf Cluster, particularly for the rendering exercise? Many thanks, Owen, Five Islands School, St. Mary's.
    May 4, 2010 6:42 PM UTC
    Owen, Sorry for the delay in responding to your post. The DPI can be controlled when saving to a Postscript or Tiff file (use View> Model Setup> Render Setup). In the Render Setup dialog, you will see all export types. Unfortunately, I do not see a .spl type. I'd like to see your assembly as 4-5 hours seems like a very long time. Is your assembly that big? Send me an email at - if you need me to take a look at the assembly. Regards, Adam Haas Education Programs
