Renew Creo 3.0 student license?
Just recently,, I discovered that my license for Creo 3.0 student edition has expired and I can't find anything about renewing the license (I am still a student) Where can I renew my license?
    Hi Ian,
    Here is the relicensing guide: Relicensing Guides
    Abdul
    Emeritus
    June 22, 2016
    For the fastest response to your issue, your best bet is to fill out the PTC Academic Request Form- in addition, I am moving this to the Academic area to get eyes on your question.
    Best,
    Toby
    Hi Ian,
    Abdul
    icasciola1-VisitorAuthor
    I seem to have more problems than I thought, the guide asks to navigate to a file and find reconfigure.exe, that executable doesn't exist inside the stated directory, or anywhere for me, I have uninstalled and reinstalled parametric and it still doesn't appear. Any fixes?
    Hello Ian,
    I had your problem,i had to re-license my software also after 1 year. Just follow the license guide Abdul posted and you should be fine. It worked for me.
    La mia licenza di creo 3.0 K12 student è scaduta. Nella cartella C:\Program Files\PTC\Creo 3.0\M010\Parametric\bin non è presente il file reconfigure.exe e neanche setup.exe. Nella cartella C:\ProgramData\PTC\Licensing è presente il file BE400407EDSTUDENTEDK12_license.dat
    I think your only option is:
    • uninstall Creo 3.0 (all its items)
    • remove PTC sub-directory in C:\Program Files directory
    • remove license file from C:\ProgramData\PTC\Licensing directory
    • install Creo 3.0
