save a copy assembly window issue? creo 2.0
  • March 2, 2013
  • 6 replies
  • 2617 views
has the issue with "save a copy" assembly window resolved in creo 2.0 M030?
    What specifically was the problem you had with Save As for assemblies?
    finally someone asked? I have posted a video also on the issue? i will upload the video here also... Video Link : 3785
    As you can see in the video the "save copy " window does not come up properly..then when i try to move to move the window to see the other options in does not move....how will i be able to save copy in this way???????????????
    I searched and I think found your original video. http://communities.ptc.com/message/198051#198051
    From the video it looks like the vertical resolution of your screen is too low to display the full height of the dialog. The minimum spec for Creo 2 is 1280 x 1024. We have the same problem in high schools who have low spec screens.
