Schools Configuration - Stuck
Hi:
I am having difficulty configuring for the PTC Creo for schools.  When I run the .bat file I get the error that the file is not copied when I extract the zip file to ....\PTC\PTC Creo 3.0\[]\Parametric\common Files\Creo_standards
If I extract to \PTC\PTC Creo 3.0\[]\common Files\Creo_standards, I get the error of "Access denied"
I believe I have set the proper permissions.
Any help would be appreciated.
    robie1-VisitorAuthor
    Does anyone have suggestions on how to set permissions so that I can write to C:\Program Files\PTC\Creo 3.0\Common Files?  I have followed instructions from
    PTC Creo 2.0 & 3.0 – Schools Configuration Guide, but continue to get an "access denied" error when I run the .bat file
    There's a specific community for the schools edition here:
    Schools Program
    Ryan Kelley‌, can you move this thread so he can get the help he needs?
    Thanks for notifying me, Doug Schaefer‌. I've moved this discussion into our Academic Support‌ community so our team can review and respond.
