Script error in PTC Creo
We are having an issue with our PTC Creo 3.0. When you launch it, it gives an error about an unresponsive script. The link for the script is to LinkedIn. Is there anything that can be done about this? Sometimes it can cause the program to hang, so it is a bit of a pain.
    I guess that the problem is related to integrated browser. Add following option at the end of config.pro file to display blank page in the browser.
    web_browser_homepage about:blank
    MH
    jstaples1-VisitorAuthor
    That did not make a difference.
    Try the config setting js_error_policy suppress_continue
    2-Explorer
    May 12, 2017
    Add the offending site to the hosts file.
    See https://support.rackspace.com/how-to/modify-your-hosts-file/
    Set the address to 0.0.0.0 and the website to dc.ads.linkedin.com
    This will cause the OS to direct any request for that website to the home (0.0.0.0) which is your computer. Since your computer doesn't know anything about it, there won't be any script to load in the first place, so no script error.
    I think this won't cause any other message to pop up. If you don't like the effect, edit the file again and remove the entry.
    See hosts (file) - Wikipedia
    You may need to have admin rights to  change the hosts file; this is to prevent malicious actors from doing it for you. Basically it acts like putting a different number in the speed-dial on a phone to call someone else.
    Sharing an easy fix that worked for me.
    Lookout for the "Windows_browser_type" in config,
    by default this is set to : "ie_browser"
    Change this to : "Chromium_browser"
    Save this to your default config.pro
    Say goodbye to all the script errors once and for all!
