Mar 4, 2012 7:53 PM UTC
Script Error message with Precision LMS within Creo browser
I have tried to access Precision LMS through the browser in Creo 1 Parametric M020. No matter what page I try to access I consistently get a window pop up stating Script Error and below the message 'An error has occured in the script on this page.' Any suggestion? Should I only access PLMS outside of the Creo Browser? Incidentlly, I run Creo on my iMac using Parallels 7. Any advice gratefully received.
    18-Opal
    Mar 7, 2012 8:41 PM UTC
    Hi Paul,
    Can you access PLMS from an external browser?
    What server are you connecting too?
    Mark
    Mar 7, 2012 11:09 PM UTC
    Hi Mark
    I can access PLMS from an external browser. Regards the server I'm using - well you have me on that one! I'm accessing PLMS from the UK so take your pick. All this is not a major issue as I can access PLMS only a little frustrating.
    I have just installed Creo 1 M020 on my iMac and I'm getting a problem you provided me with a fix for sometime ago. Once again I'm getting no ghosted image when extruding only a series of lines. It is only when I accept the extrude do I get the shaded model. Do I carry out the same fix you provided me with previously?
    Paul
    18-Opal
    Mar 8, 2012 12:19 AM UTC
    Hi Paul,
    Can i connect to your machine tomorrow and take a look?
    The issue you are having with the lines is mostly related to a graphics issue...which could be a result you are using it via bootcamp or Parallel.
    The fix I did last time would resolve this.
    As for connecting to PLMS....I can setup the application to connect to PLMS.
    Lets try and connect tomorrow.
    Mark
