Should I have admin privileges for my Academic site?
The URL of my cloud-based instance is:
If this is a multi-tenant site I can see why I would not be given an admin user name and password. If this is a containerized instance for my use alone, perhaps I could be given admin rights.
I think my lack of success for using the monitoring UI from the Composer that I have posted about before could be because my access rights are restricted.
I tried a bunch of other things to monitor and they show nothing of interest either. I will upload a screenshot for what I see when I try to Monitor the system.
jamesso1-VisitorAuthor
I posted this over a week ago and still no answer.
I would have expected that as this is a simple question I would not have waited long for an answer.
How can I monitor my remote things? The Raspberry Pi demo/tutorial indicates that I should be able to accomplish this.
Adrian says PTC can't/won't grant admin rights so that monitoring is available.
So I strongly recommend that the documentation be changed as soon as possible. This is a very misleading bit.
I wonder if an academic user is better served by having a local install rather than a cloud instance if this administrative experience is denied to them!
Hi James,
      I wanted to let you know that I've recently met with the development team and there appears to be a way in the next release that could potentially enable users to access the import/export feature as well as read the monitoring log inside the ThingWorx platform (Composer) without having to be an Administrator. I am going to investigate this and get back to you.
Best regards,
Hi Adrian,
Do you have an email address? I am having the same problems as James ans would like to get administrator access as well. Both for the monitoring and import/export features.
Sincerely,
Walter
Hi Walter,
    Can you please add your email address here? I will contact you through email regarding your request for an Administrator right.
Best regards,
Thanks for checking and looking forward to the improvement.
The cloud version is still 5.0.2.33 so upgrading that to the latest (5.2?) would be appreciated as well.
Jim
