Simulating with Creo 11.0.0 student license / using license pack
When I go to the Live Simulation tab in Creo, I'm prompted to check the Floating Licenses in the File>Options menu, because the "license request failed." Is this feature included with the version I'm using?
EDIT: After writing the message, I see I got an email titled "PTC License Pack". How do I use the file? When opening it with Creo, I get an error.
Max
@MS_13466646 wrote:
I registered for the University license, and I think this email I mentioned contains the license. How do I access it?
1.) save license file to local disk ... eg. into C:\PTC\mylicense directory
2.) in Notepad ... modify parametric.psf file located in Parametric\bin subdirectory in Creo loadpoint
You have to modify following lines ...
ENV=PTC_D_LICENSE_FILE-=
ENV=CREOPMA_FEATURE_NAME=
If you do not know how to do it ... please upload license file and parametric.psf file. I will do modification for you.
Quote: "Creo Student Free doesn't have Creo Live Simulation included. You need to use the University license for Simulation or purchase from the PTC eStore a Creo Student Premium license". From - "Creo 11 Live simulation License": https://community.ptc.com/t5/PTC-Education-Forum/Creo-11-Live-simulation-License/td-p/971380
