Jan 15, 2022 11:55 AM UTC
Sprache umstellen/Switch language
As per this thread, similar issue:
I did what you said with creo 5.0. But it didnt works. When I open Creo there is also a skriptproblem. Pls helps me thanks!
@MartinHanak
Jan 16, 2022 3:50 PM UTC
@MartinHanak
please provide more details about your problem. "It doesn't work" information is not enough.
Jan 16, 2022 9:16 PM UTC
So i added "ENV=PRO_LANG=german" into parametric.psf. I saved it an opend Creo. The language is still in english. An there is also a Pop-up what says skript error. I hope you can understand what I said @MartinHanak .
Jan 17, 2022 7:00 AM UTC
1.]
Did you check german language option during installation ?
Please search Creo installation directory tree to see if it contains subdirectories named german.
2.]
It is possible to turn off native langue using following config.pro options.
Please check the contents of your config.pro files.
dialog_translation no
help_translation no
msg_translation no
menu_translation no
