unable to edit assembly made on other computer
One of our student made an assembly of our robot. We are trying to edit it on a laptop and we cannot do it. When we right click on the parts, we do not see the full menu of items, just the info list. How can we edit the assembly on another computer?
Thanks for your help.
    sm_01Answer
    There should not be an issue going from one computer to another. I'm assuming your both using the same major release of Creo and both using a student license. From what you've described, it shound like the Assembly is not the "Active" Window in Creo. If it happens again, try pressing Ctrl-A to activate the current window.
    sm_011-VisitorAnswer
    ccabana1-VisitorAuthor
    Thank you very much, it worked. We are still new using this software and are still on a learning mode.
