Upgrading To Creo Parametric 3.0
We are FTC team #8521, and we have just finished our season. Now we would like to upgrade to Creo Parametric 3.0 from Creo 2.0. We just have a few questions.
  1. If we upgrade to Creo 3.0, can we access and load Creo 2.0 files? Also, can we view Creo 3.0 files in Creo 2.0 if necessary?
  2. Can we keep both Creo 3.0 and 2.0 on our computers? Would we have to switch back in forth, or is it possible to run 2.0 and 3.0 in parallel?
  3. Is there anything special that needs to be done to connect Creo 3.0 to Windchill? Or are we able to use the same process to connect?
Thank you very much,
Trevor A. Babb
Hard-Hitting Hardware Hooligans
#8521
    sm_01Answer
      YES.
      NO, CREO IS NEVER BACKWARD COMPATIBLE.
      YES, IF DESIRED, YOU CAN KEEP BOTH VERSIONS INSTALLED. THEY WILL REQUIRE UNIQUE LIECENCES SINCE THEY ARE NOT CROSS COMPATIBLE.
      SAME PROCESS.
    sm_011-VisitorAnswer
      YES.
      SAME PROCESS.
    Thank you very much Mr. Morris!
    _________________
    aliiiiii
    It is the same process. If you have already registred Windchill with Creo 2.0, it will show up after you start Creo 3.0.
    Is it possible to rename your team's project, if your team's name changes?
