Upload\Checkin errors from Creo to Windchill
Are there incompatibilities with Windchill and IE 10? It is working sometimes... and then not other times. We can access and files in Windchill from Creo. But the activity of uploading or checkin work some times and not other times. We have Google Chrome on the PC... if there is an option to define that as the browser CREO uses. Attached is view where we were able to check in 3 of 5 parts\assemblies. We are able to open the assemblies in the work space. Attached are some screen views of the situation with some of the parts\assemblies uploaded... and some not. I tried setting the windows_browser_type = mozilla_based_browser... and this option does not work with IE 10.
    sm_01Answer
    Peter, you are correct. When it comes to CAD Data management with the FIRST Windchill server, Internet Explorer 10.0+ is not supported. For a consistent experience, I would strongly suggest running IE 9 on your client machines if at all possible. I understand there are some cases where this is not possible, such as Windows 8.
    At PTC, we are doing everything we can to upgrade this server to the latest version of Windchill that supports IE 10. Until this time, the only option available to you other than an IE downgrade is the config.pro option you mentioned, windows_browser_type. When set to mozilla_based_browser, the Creo embedded browser will use mozillla rather than IE.
    There is no option to use Chrome as the embedded browser in Creo.
    sm_011-VisitorAnswer
    Can you give a little more explanation around what is being depicted in your screen shots and what commands you used to get to these points?
    In the first image, you are showing a workspace with three objects checked into Windchill and 2 new ones. In the second image, you are attempting to edit the attributes of all 5 items at once and the three checked in items are flagged as inelligible for attribute changes becuase they are checked in and do not have any attributes defined which are available for modification. The two new items allow you to change the folder location as an attribute, only becuase they are new.
    Neither of these screen shots are from an attempt to check in. I'm assuming you should be able to check in the two new objects if you pick the two of them and pick the check in button.
    pladuca1-VisitorAuthor
    We were trying to upload the 5 objects and check them in. We tried them as a group several times... and also individually. I don't think I did anything different... but on some of the attempts trying to checkin one object at a time... Windchill accepted the checkin. That is how 3 of the 5 objects were checked in. The last 2 objects we kept trying... and did not succeed in checking them in. We did try several times to pick just the 2 items not yet checked in... and check them in. The system would think about and then not make any changes. My understanding from the above email thread is that we are running into a incompatibility with IE v10.
