Using same part with different dimensions
I am looking for the solution to my problem: How can we use a single part in an assembly with various dimensions,
I wanted this to change the length of the Bosch Aluminum Profiles without making different part file of variable length in an assembly model.
Regards
Yash Yadav
8-Gravel
January 23, 2018
for simple solution, try Family Table. You can add series of dimension with excel table on it.
