Jan 26, 2012 6:05 PM UTC
Windchill Server problems??? HTTP SOAP errors
Been getting HTTP SOAP errors when accessing WINDCHILL from School wireless and hardline as well as on Corporate Internet. Making using CREO/Windchill online almost impossible to use. Sometime have to go in and delete ..../.wf directory and start over.
    Feb 15, 2013 1:52 PM UTC
    So it could have been related to an updated firewall or possible DNS registration issues.
    Jan 28, 2012 7:18 PM UTC
    Yes! Our team has been encountering a similar problem: Limited Windchill 10 Access via Creo Parametric 1.0 M020 . We tried the same thimg, delete the .wf. It seems to resolve the issue for awhile, but it reoccurs in the next work session.
    Hope we can find a solution soon!
    Jan 29, 2012 4:00 PM UTC
    Even deleting .wf is not working now. Do not know how Windchill "reacts" to deleting the local .wf Workspaces with respect to the Workspaces on the PTC Windchill server. Can go in to Windchill vis Browswer and delete them but not sure what that will do either.
    Jan 30, 2012 3:53 AM UTC
    Hi Stuart,
    Can you take a look at your Cache numbers in the Creo Server Manager window? Is the Cache used bigger than your available disk space? Is it bigger than 2 GB?
    You might try playing with the dm_cache_limit config option if you're getting big numbers. I'm just taking a guess right now. I'm really not happy with the performance and errors that we've seen so far.
    Josh
