MarcoTosin
Apr 14, 2026 10:15 AM UTC
Article CS336353 not visible
Hi ​@PeterCase,
below article is no more visible to customers.
How to install & configure Jasper Report Studio
https://www.ptc.com/en/support/article/CS336353
Could you please check why this is happening and see if it's possible to make it visible again?
Marco
Thank you very much
Apr 14, 2026 4:23 PM UTC
Community Manager
Apr 14, 2026 12:18 PM UTC
Hi ​@Marco Tosin, I checked the history and this article was removed from customer view in March 2024 after the Plugin was removed from Marketplace by Eclipse. I’ve added ​@RomainGarcia  for next steps and a decision on republishing.
Many thanks,
Peter.
Hi ​@Marco Tosin , I confirm that the Plugin was removed. Please have a look at: Article - CS384997 - Jasper Studio Plugin is no longer available from Eclipse Marketplace to be configured with Jasper Reports in Windchill PDMLink.
Within this article, there was a link to: PTC Windchill Help Center and Installing Jaspersoft Studio - v7.2.0 - Jaspersoft Community
Romain
MarcoTosin
Apr 15, 2026 6:22 AM UTC
Hi ​@RomainGarcia,
I just read article CS384997.
At the end, there’s a line that says:
Update: Jasper Studio is already back in the Eclipse Marketplace.
However, if the article being discussed here is no longer valid, it should probably be removed from this HUB article as well:
https://www.ptc.com/en/support/article/CS332405
Thanks for your help.
Marco
Apr 15, 2026 11:03 AM UTC
Thank you for the feedback,
Indeed, Jasper Studio Plugin is no more available in the Eclipse Marketplace so we are going to remove the references to this article.
Thanks a lot for your vigilance!
Romain
