Mar 18, 2022 12:46 PM UTC
Hi @Marco_Tosin,
It seems to work on my side : https://www.ptc.com/en/support/article/342750, do you still see this issue?
If yes, can you try forcing the language as follows : https://www.ptc.com/en/support/article/CS342750?art_lang=en  ?
TomU
Mar 18, 2022 12:55 PM UTC
I see the same message from both links:
Mar 18, 2022 1:08 PM UTC
Same.
Mar 18, 2022 1:55 PM UTC
Hi @Marco_Tosin ,
This article is in an expected state within our Knowledge Base. We are currently investigating what caused it and how to fix it.
Can you confim that you have this issue with this article only, and no other?
Also, in the meantime, here is the English content:
TomU
Mar 18, 2022 1:59 PM UTC
@Jean-Christophe,
I'm not @Marco_Tosin but I can confirm that I've been viewing other support articles all morning without any issues.  This is the only article appearing this way at the moment.
