TomU
Apr 5, 2019 12:41 PM UTC
Case lookup tool not finding closed cases
There seems to be a problem with the case lookup tool under the 'My Active Request' section of the support page.
It fails to find any case that is closed:
This case number is definitely valid:
Emeritus
Apr 8, 2019 3:41 PM UTC
Hi @TomU , thank you for bringing this to our attention, I have informed our web team who are looking into this.
May 1, 2019 10:00 PM UTC
When is this problem going to be fixed? I am having the problem again today 5/1/2019.
Wayne Schrock
Emeritus
May 2, 2019 8:44 AM UTC
@WayneSchrock the web team have this on their roadmap to fix in July. In the meantime, you can view any case using the direct Case tracker URL and appending your case number: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case= for example: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=98765432
Emeritus
Jul 22, 2019 1:05 PM UTC
Hi@TomU, a quick update, the web team have fixed this issue. You can now search for cases again.
