Mar 19, 2022 11:02 AM UTC
Contact eSupport for Subscription License Buyers.
I feel bad about submitting these ideas, but we feel contradicted and troubled.
We use CED 20.0.3.0. CED 20.0.3.0 is no longer supported by PTC as of March 31, 2020. We understand that it is difficult for PTC to support all previous versions. However, we have purchased a subscription license that includes support fees. Therefore, a user who has purchased a subscription license has the right to contact eSupport even if the defect of the used version is not corrected. ptc should respond to eSupport inquiries from users who have purchased a subscription license, regardless of the version used, or should reimburse support fees for users who use a non-supported version.
Mar 21, 2022 5:49 PM UTC
CED 20.0.3.0 as released almost 4 years ago with a known end of support date of March 2020.
The product is still supported, just with newer releases, which your subscription entitles you to use.
I would suggest downloading and installing CED 20.4.1.0 and see if the latest release may have solved your problem already.
Mar 27, 2022 7:13 AM UTC
Thank you, sir. I understand your proposal. However, we cannot upgrade the version because there are some our problems. In the meantime, as for Modeling, we can contact technical support if we can confirm that the problem occurs in the supported version. However, Model Manager can't build an environment with the supported version, so we can't see if the problem occurs.
Mar 28, 2022 5:50 PM UTC
Is the problem with Modeling, with ModelManager, or both? If you could please provide a bit more information, we may be able to help.
Thanks!
andy
