TomU
Aug 1, 2022 8:13 PM UTC
New KB Article Feedback Widget
The new KB article feedback widget at the bottom of the page needs some cleanup.
  1. I'm guessing 'AFwidget_Label_Dismiss' is not the intended button name.
  2. 'Top' is positioned off the bottom of the page. (Look at the bottom right corner.)
olivierlp
Community Manager
Aug 2, 2022 2:02 PM UTC
Thanks for the note. We are looking into this.
Olivier
TomU
TomU23-Emerald IVAuthor
Aug 2, 2022 2:07 PM UTC
@olivierlp,
I sort of wish 'Something is wrong in this article' just said 'Provide Feedback' instead.  It leaves one unsure how to proceed when trying to provide feedback or additional information, but nothing is actually wrong with the article.  An article can be incomplete or improved without necessarily being wrong.
Aug 2, 2022 2:20 PM UTC
@TomU
Thanks a lot for the suggestion and feedback. We are actually looking at improving our Article Feedback widget. We are currently running an AB testing with a new variation  with the following 2 options: This is what I needed / This article needs improvement. The experience you have with the widget is indeed not the expected one (you should only see the "dismiss" option) instead of 'AFwidget_Label_Dismiss' and Top. the issue is being handled by the team in charge of the Article Feedback Widget. Thanks.
Camille
