TomU
Apr 3, 2017 4:01 PM UTC
Proactive Support Recommendations - Links Don't Work
Each day I receive an email with from PTC with content based on my subscription preferences.  The top of this email includes a section called "Proactive Support: Windchill".  In this section there are multiple recommendations, each with a unique ID that looks like it should lead directly to each specific recommendation.  Unfortunately, all of these links simply lead to the Creo Performance Advisor main page.
https://support.ptc.com/apps/jump/ssl/auth/Recommendation.jsp?Name=R-0007894
Do these links work correctly for anyone else?  Is there a quick way to get to each of these specific recommendations without having to manually comb through all of the recommendations for every single Windchill server?
2-Explorer
Apr 3, 2017 6:57 PM UTC
The behavior looks like a default for getting a request the web server doesn't understand. I would guess from the /ssl/auth/ section that it expects you to be logged in somehow, but doesn't take you to the login so the server fails over to the other page.
When I try, it does take me to the login page, then fails (because I don't have maintenance), but takes me to a page indicating the correct recommendation and tells me I don't deserve to see it.
"Your account does not have access to Recommendation R-0007894."
TomU
TomU23-Emerald IVAuthor
Apr 3, 2017 8:01 PM UTC
Yes, one would definitely need to be logged in.  These are customer specific recommendations.  Once logged in the URL just redirects to https://support.ptc.com/Thingworx/Runtime/index.html.  Not sure why it won't go straight to the actual recommendation...
2-Explorer
Apr 3, 2017 9:46 PM UTC
Maybe open a support case with support? Seems like a Catch-22. Best of luck.
MarcoTosin
Apr 4, 2017 6:52 AM UTC
If I choose an ID link I can see that recommendation.
Marco
TomU
Apr 4, 2017 11:59 AM UTC
What does the URL look like when you're on this page?
MarcoTosin
Apr 4, 2017 12:02 PM UTC
