Mar 30, 2016 12:33 PM UTC
Product Calendar - Missing Information
I was searching for information on the support status of Creo Elements/Pro 5.0 (CEP5). When I look at the product calendar:
http://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm
I see no entries prior to Creo 2.0.  When I look at the archive calendar:
http://support.ptc.com/cs/product_calendar/PTC_Product_Calendar_Archive.htm
And browse to the Proe section:
http://support.ptc.com/cs/product_calendar/PTC_Product_Calendar_Archive.htm#RANGE!A359
There are no entries past Pro/Engineer WF1. That leaves a gap with no information on WF2, WF3, WF4, WF5, CEP5 and Creo 1:
I opened a case with tech support, but when he browses the the archive calendar he sees much more information (I'm not sure about the main calendar):
Is anyone else seeing what I'm seeing?
MarcoTosin
Mar 30, 2016 12:43 PM UTC
Hi Doug,
I saw the same behavior following your links, even browsing from tech support page.
Marco
Mar 30, 2016 1:08 PM UTC
It turns out that if you scroll down on the archive calendar, the rest of the Proe, the CEP5 and the Creo Parametric entries are there.  Poorly laid out, and they are supposed to correct it.  In the mean time, scroll down, it's there.
Mar 30, 2016 9:46 PM UTC
Hi Doug,
Thanks for pointing this out.  The archive page has been updated to group all Pro/ENGINEER releases.
Mar 31, 2016 12:53 PM UTC
Fantastic, thank you.
