MarcoTosin
PTC support site down again?
  • May 31, 2018
  • 5 replies
  • 5522 views
Am I the only one unable to access PTC support site?
I can't read any article (see below error).
Server Error in '/' Application.
Invalid JSON primitive: An.
Description: An unhandled exception occurred.
Exception Details: System.ArgumentException: Invalid JSON primitive: An.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[ArgumentException: Invalid JSON primitive: An.]
 System.Web.Script.Serialization.JavaScriptObjectDeserializer.DeserializePrimitiveObject() +707
 System.Web.Script.Serialization.JavaScriptObjectDeserializer.DeserializeInternal(Int32 depth) +333
 System.Web.Script.Serialization.JavaScriptObjectDeserializer.BasicDeserialize(String input, Int32 depthLimit, JavaScriptSerializer serializer) +110
 System.Web.Script.Serialization.JavaScriptSerializer.Deserialize(JavaScriptSerializer serializer, String input, Type type, Int32 depthLimit) +46
 System.Web.Helpers.Json.Decode(String value) +59
 PTC.Web.Models.Support.Apps.SupportCommon.GetLangFilterJsonData(String message, String messageLang) in D:\PTCWebsite\ptcwebproject\CodeLibrary\PTC.Web\PTC.Web\Models\Support\Apps\SupportCommon.cs:159
 PTC.Web.Models.Support.Apps.SupportCommon.GetFilteredMessageData(String message, String[] messageIds, String MessageLang) in D:\PTCWebsite\ptcwebproject\CodeLibrary\PTC.Web\PTC.Web\Models\Support\Apps\SupportCommon.cs:139
 PTC.Web.Controllers.Support.Apps.ArticleViewerController.LoadArticleDetail() in D:\PTCWebsite\ptcwebproject\CodeLibrary\PTC.Web\PTC.Web\Controllers\Support\Apps\ArticleViewerController.cs:73
 lambda_method(Closure , ControllerBase , Object[] ) +87
 System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +229
 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +35
 System.Web.Mvc.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() +80
 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +453
 System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +533
    MarcoTosin
    Now article are again readable.
    Marco
    I'm still having trouble today.
    It seems to be getting worse...
    MarcoTosin
    At the moment everything is ok for me.
    Marco
    Down again right now, and no communication from PTC
    Can't open any CS
