3-Newcomer
Nov 18, 2026 2:53 AM UTC
Creoオンライン学習後のガイドブックについて
オンライン学習を受講し、受講後のガイドブックで復習をしようと思います。トレーニング中は(オンライン中)は御社のCreoを用いて学習をしたので、ファイル陶のモデリングは御社サーバーにあると思いますが、、、実際に、復習する場合、ログイン等すれば御社のサーバーのファイル(モデル)を使っての復習はできるのでしょうか?できなければ、どのように復習すれば良いですか?
Nov 19, 2026 5:08 PM UTC
Hello!
The training guidebook is available for 2 years after you have taken the course, so you should be able to access the PDF for that duration. The models, as you suggested, are only available in the virtual machine (server) and are not available outside of it.
I suggest that if you want to access these files to review different exercises from the training guidebook to register for Fundamentals of Solid Modeling 1 again, but in the self-guided format. This will enable you to provision a VM for 3 hours so you can access the models again and review the exercises.
LInk is here: https://learningconnector.ptc.com/course/346/creo-fundamentals-of-solid-modeling-1
You can click Access Guidebook to open the PDF. As mentioned, the guidebook is available for 2 years after you take the course.
Click “Open Course as Self-Guided” to provision a Virtual Machine (VM) so you can access the models.
Hope this helps!
Matt
