3-Newcomer
Oct 23, 2025 7:14 AM UTC
Issue with Folder Visibility in “Creo: Practice Routing Wires and Cables” self-guide training VM
During the “Creo: Practice Routing Wires and Cables” self-guide training, I launched the virtual machine and checked the folder path indicated in the student guide. However, only the exam folder was visible as attached pdf. Could you please confirm if this is expected or if there might be an issue?
Oct 23, 2025 1:50 PM UTC
Hello!
Yes, you are absolutely correct. Somehow this weekend when we switched over all the VM images from Creo 11 to Creo 12 the wrong image was assigned to this particular grouping of courses. We have fixed the issue now, so you should be able to re-enroll in the course and take it properly. I had the Systems folks un-enroll you from the course so you should be set.
Apologies for the confusion here.
Matt
