8-Gravel
Sep 23, 2014 7:48 AM UTC
About cabling template?
I didn't find cabling template in template folder,but I read the cabling tutorial,it utilizes a template called "MM_KG_SEC_ASSY.ASM",so is this template some special compared with other templates?Can I use other design template instead?
Sep 23, 2014 2:41 PM UTC
To my knowledge, there's nothing special about that template. You should be able to use your own design templates in place of that one.
Thanks!
-BRian
