May 16, 2024 9:10 AM UTC
Creo training central download files
Hi All,
I'm trying to prep a company wide training diet and want to use PTC's training central playlists as part of this, there are references to pre existing files throughout this training, a drone assembly being one, are these files available as a download or are they buried in the Creo installation somewhere?
I'm probably missing something obvious but any help would be appreciated,
many thanks
Dave.
Chris3
May 16, 2024 1:18 PM UTC
May 23, 2024 12:51 PM UTC
Hi Dave,
Of all the tutorials in Learning Connector, the only lab files that can actually be downloaded are for the playlist Get Started with the Creo Parametric Interface.
We moved away from lab file downloads for a variety of reasons. To that end, we're trying to create playlists wherein the student actually creates their own lab files as they progress through the tutorials and/or they leverage these models in other playlists.
In the playlist Get Started with Creo Parametric Assembly we provide a PDF drawing that you can download to model each of the drone components that are assembled in this playlist. This would be the drone assembly that you're looking for.
These models are also used in Learn More About Creo Parametric Modeling, Get Started with Creo Parametric Analysis, Get Started with Creo Parametric Documentation, and to some degree Get Started with Creo Parametric Sketcher.
At this point I am not aware of Creo Parametric containing any example data sets as part of the install. I'm inquiring with Product Management to see about the potential of this, as some of the other PTC software does include example data sets (Creo View, for example).
Hope this helps.
Matt
May 28, 2024 2:37 PM UTC
I've gone through the drawings and found that I'm missing the following pieces of information from the drawings.
  1. Drone Body
    1. The radius on the outside legs of the drone
      • I found it as 12.5 in the sketching tutorial - but it's not on the drawing.
    2. The diameter of the top cylinders
  2. Camera
    1. I'm having a conflict between the 65 "OAL" dimension and the 15 length on the tab. With the 45 + 15 + 10 the OAL should be 70.
  3. Camera Mount
    1. I don't have the length of the Ø25 cylindrical portion
  4. Rotor Blade
    1. The depth of the Ø7.5 counter bore is missing.
May 28, 2024 2:55 PM UTC
Camera can be designed with those values, it just looks a bit different. It puts the 7.5 hole closer to the full radius instead of both being on the 15 dimension.
The 'screws' have no thread pitch callout and the hex should be dimensioned across the flats, not across the hex.
