Jun 17, 2019 10:33 AM UTC
how to run reverse sequence in vuforia studio
how to do reverse sequencing in creo illustrate and how to run it on vuforia studio
jirvin-2Answer
Jun 20, 2019 7:20 PM UTC
Once you create a sequence and you want to reverse it, you’ll have to show the reverse steps in your illustrate file. To learn how to create sequences, I recommend the Creo Design & Sequence for Augmented Reality course offered by PTC University.
As for how to run a sequence in Vuforia Studio:
  1. Add your published sequence (zip or pvz file) as a resource to your Studio project
  2. Use a model widget to augment the Creo data
  3. Once the pvz file has been applied to the model widget, set the model widget’s Sequence property to the appropriate one (if you have multiple sequences)
  4. Use a button widget or JavaScript to run the model widget’s associated sequence services such as Play, Rewind, Play All, etc.
-Jill
jirvin-212-AmethystAnswer
-Jill
InfinityX1-VisitorAuthor
Jun 25, 2019 6:47 AM UTC
thanks
