Nov 11, 2015 7:40 PM UTC
How to use proprogram
Is a there a detail tutorial somewhere that demonstrates how to use program effectively?
TomU
Nov 11, 2015 9:47 PM UTC
Start with the online help:  http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/#page/pma/fundamentals/About_Pro_PROGRAM.html
Then ask questions!
In the simplest form, you are simply putting IF / END IF block around features in order to suppress and resume them based on some parameter or dimension value.
2-Explorer
Nov 12, 2015 12:56 AM UTC
There's also this:PTC Pro/Program Webinar - YouTube
A nice use of Program is that one can re-order the model tree using a text editor, though it can't create/remove/edit groups. Sigh.Good news is that it doesn't blow up and instead fails gracefully and undoes all the changes that led to failure.
2-Explorer
Dec 3, 2015 6:16 PM UTC
Hello Jeffery,
Were the suggestions from Tom and David helpful?
Did they answer your question?
Gunter
Dec 3, 2015 7:59 PM UTC
Hello Tom and David,
Thank you guys very much for your responses.  Both resources was a huge step in helping me determine what I need to modify in the pro/program to achieve what I wanted to do.
Thanks again,
Jeff
