Mar 7, 2011 10:41 AM UTC
Looking for Tutorial for sheet metal
i am looking for a tutorial for the sheet metal package, i am trying to use it to create a cover over to existing parts and i was hoping it would help me design one that simply fits exactly to the existing contour and afterwards unfolding it so i get a drawing for the cutting machine.
highway45Answer
Mar 7, 2011 4:49 PM UTC
No problem modeling the sheet part as a normal volume.
Before using the unfold function you have to give the part a material and must declare every edges as bendings.
The bended edges must not be sharp but with radius in the correctly thickness of the sheet.
Mar 7, 2011 1:38 PM UTC
Mar 7, 2011 2:58 PM UTC
Unfortunately it doesn't since i'm using Creo Elements/Direct (CoCreate Modeling) and not ProE and apparently the usage differs a lot between those two.
Mar 7, 2011 3:05 PM UTC
Ah, sorry. I use CreoElements/Direct. Click on help - help topics & it shows the basics on creating workplanes, adding lips, corner relief etc.
How complicated unit do you need to produce ?
