Dec 18, 2012 10:39 AM UTC
Mechanica load intervals
Gurus,
I've run up against the limitations of my training: if I configure a contact analysis to run with multiple load intervals, how do I view results for the intermediate ones?
Thanks!
Jonathan
Dec 21, 2012 10:57 AM UTC
In your analysis definition you can select how many load intervals you
want, and you can select to keep results for each interval.
For some reason though, I can only select this for large deformation
analyses, not for contact analyses (WF4).
It would be good to ask PTC why this is. (I'm curious about their
answer).
Of course a workaround can be to create several analyses with different
loads... not ideal, but it will work.
Best regards,
Patrick Asselman
